Noob Question
Old Jun 26, 2008 | 09:03 PM
Turconator's Avatar
Default Noob Question
I have a problem with my AC. Both my REC and AC off lights are blinking. After a self diagnostic, the code given was a 4 - 1 - 8 (No control signal to Blower Fan Power stage). I have checked the blower and I'm getting about 11.94 - 11.98 volts coming through but my fan will NOT engage or turn on at all. Do u think that I have blown out the blower motor or do u think its the ECC that has gone bad or something else? I would really like some help with this problem. Any advise would be great.
Old Jun 26, 2008 | 09:39 PM
bitter356's Avatar
Default RE: Noob Question
If you have 12volts at the blower motor and it is not operating. Make sure you have continuity to ground on the solid black wire. If so, bad blower motor.Good hunting!
Old Jun 26, 2008 | 09:54 PM
Quick Brick's Avatar
I agree with Bitter356.
If you connect the fan to 12 volts and ground and the fan does not run then the fan is done .
[sm=icon_cheers.gif]
Old Jun 27, 2008 | 08:11 AM
Ozark Lee's Avatar
You have a bad power stage. The fan always has battery voltage on one side and the speed is varied through a MOSFET transistor inside the power stage which is tied to ground.
...Lee
Old Jun 27, 2008 | 08:24 AM
Psaboic's Avatar
I would take the blower motor out and bench test it. If it checks good, reset the codes, put the motor back in and see if the problem repeats itself. Agree....good hunting!
Old Sep 20, 2008 | 12:13 PM
Turconator's Avatar
Sorry about the late response but a while back i bench tested the blower motor and it automatically turned on. I replaced the power stage but nothing changed, my a/c still won't work. But i forgot to mention that before i did a trani rebuild, the a/c worked and upon finishing the trani the a/c wouldn't work at all and i was getting a 4 - 1 - 8 code. Is there something near the transmission that would have caused this problem? Love to hear back from anyone.
Old Sep 20, 2008 | 03:33 PM
Maybe the controller went bad.
Old Sep 20, 2008 | 08:26 PM
Turconator's Avatar
I know this is a stupid question but what controller are you talking about??? The ECC or something else?
Old Sep 21, 2008 | 07:09 AM
Yes the ECC controller.
Old Sep 21, 2008 | 08:03 AM
Turconator's Avatar
ok i have a spare one that i got off my old parts car.... i'll try that and let you guys know. Thanks for the advice.
Old Sep 23, 2008 | 08:35 AM
Turconator's Avatar
Bad news guys tryed to connect my spare ECC today but the same thing happened. Nothing. Do you guys have any more suggestions about this because im stumped.
Old Sep 23, 2008 | 07:27 PM
Lights still flash?
Old Sep 24, 2008 | 08:44 PM
Turconator's Avatar
Found out the problem with the A/C. It was the blower motor resistor. My spare one off my parts car must have been bad too. So i ordered a new one through Volvo and it worked no problem. Thanks for all the helpful posts guys.
Old Sep 26, 2008 | 06:33 PM
Glad you figured it out and thanks for the update.
Hondu5
Nov 12, 2007 05:06 PM
FarCanal
Aug 2, 2007 03:19 AM
2002S80T6
Jul 22, 2007 10:33 AM
dano7331
Apr 23, 2007 11:50 AM
us11186
Oct 17, 2006 12:26 AM
