O2 sensor
Old Jan 13, 2008 | 09:30 PM
vetalbig's Avatar
Default O2 sensor
please give instruction how to repleace O2 sensor!
Old Jan 14, 2008 | 07:12 AM
JPN's Avatar
JPN
Default RE: O2 sensor
Remove & install.
JPN
Old Jan 14, 2008 | 07:17 AM
JPN's Avatar
JPN
Just kidding[8D].
Tell us whether your 850 is turbo or NA. Turbo should have 2 sensors; one in front of the cat converter and the other in the aft. You would know when you see it (them); they are attached onto the exhaust pipe and have electrical wires attached. It is usually best to use O2 sensor socket, which is a 6-point deep well socket used for proper removal of the O2 sensors. If open-end or 12-point socket is used, the hex portion of the sensor may strip.
Spray plenty of PB Blaster a few hours before attempting to remove. Disconnect the electrical connector then loosen the sensor and remove. Make sure you do all these with the engine cold and the ignition switch off of course.
Haynes manual may have the procedure, or other members would be able to give you more precise instruction. I would go with direct-fit OEM Bosch sensor and would stay away from universal type, even if it's Bosch.
Good luck,
JPN
Old Jan 14, 2008 | 08:38 AM
Psaboic's Avatar
JPN,
I couldn't have put it better myself <grin> I especially like that you mentioned using PB Blaster. I use that stuff and I really like how well it works.
Old Jan 14, 2008 | 09:28 AM
JPN's Avatar
JPN
Thanks!!!
JPN
Old Jan 14, 2008 | 06:09 PM
vetalbig's Avatar
thank you everyone!
the answer given by JPN was very full andhelpful!
thank you again.
Old Jan 14, 2008 | 07:01 PM
JPN's Avatar
JPN
You're welcome, I hope it goes well. Come back if you encounter difficulty.
JPN
soduku007
Oct 7, 2019 04:01 PM
ruggles
Mar 3, 2010 04:19 PM
mctan
Feb 2, 2010 03:16 AM
Scanman
Jan 28, 2010 07:01 PM
sabydady
Jul 7, 2009 04:58 PM
