O2 Sensor replacement
Old May 16, 2009 | 01:31 AM
momsmechanic's Avatar
Default O2 Sensor replacement
I just spent the better part of today changing out my O2 sensors, for preventative maintenance, been getting intermittent A2 4-3-5 codes (front O2 sensor slow response).
I got the front sensor out no problem, but the rear one gave me a bit of trouble because of the crossmember/plate that is right underneath it.
I guess the stress of the impact wrench I was using caused the threaded nuts the four bolts were screwed into to all break loose after being partly loosened.
In the end I cut the bolts off to get it off.
Here's my question, is it really necessary to have the plate there? Right now I can't put it back on because the threaded nuts are gone, (I somehow managed to fish them all out) or should I put something back there? Does it serve any purpose other than to make changing the rear o2 sensor a PITA when it get all rusty?
Thanks.
Old May 16, 2009 | 02:19 AM
nonsense619's Avatar
protection.
Old May 16, 2009 | 07:41 AM
You will be fine without it.
When I did my exhaust I had to leave it out.
soduku007
Oct 7, 2019 04:01 PM
ruggles
Mar 3, 2010 04:19 PM
mctan
Feb 2, 2010 03:16 AM
Scanman
Jan 28, 2010 07:01 PM
sabydady
Jul 7, 2009 04:58 PM
