OBDI 214 Code
Old May 9, 2013 | 08:32 AM
95850turbo's Avatar
Default OBDI 214 Code
My check engine light came on my 95 850 turbo wagon and I pulled the codes and I got 2-1-4. I changed the RPM sensor and not only do I still get the 2-1-4 code, I now get a 5-3-5 code. Please help
Old May 9, 2013 | 04:10 PM
ibified's Avatar
535 is a turbo regulator valve fault code. Did you clear your codes after you changed the sensor? And did you miss plugging something back in? Double check that - that'd be my guess.
Old May 9, 2013 | 11:05 PM
Check your work and see if you missed something or knocked something loose. You need to use the panel to reset and then see if the codes pop back up. Or easier, swing by an autozone or oreilly and have them plug into the OBDII port and get the codes cleared.
new850driver
Dec 6, 2013 06:37 AM
Squiggy
Oct 29, 2009 09:23 PM
MarkInTexas
May 26, 2009 05:28 PM
gzh
Mar 21, 2007 09:29 PM
sportsdruid
Jan 9, 2007 09:20 PM
