OBDII code P0400
Old Jun 21, 2009 | 07:21 AM
Chebucto's Avatar
Default OBDII code P0400
EGR Flow Malfunction....where do I start checking.....
Thanks in advance
Chebucto
Old Jun 21, 2009 | 08:44 AM
stojakovic's Avatar
You can try to clean the EGR valve first.
Old Jun 21, 2009 | 01:32 PM
850tony's Avatar
remove egr and clean all the crap outta it.
Old Jun 25, 2009 | 06:44 PM
Usually the intake hole is clogged.
Old Jul 10, 2011 | 07:48 AM
I popped this code yesterday. Where is the EGR valve and which end is the intake? Do I have to remove the manifold to get at it?
Old Jul 10, 2011 | 10:43 AM
TacklaNHL's Avatar
EGR valve is mounted just underneath the throttle body. Remove the hose from the airbox to the throttle body... and then see the brass hose going from the rear of the engine to a funny looking part under the throttle body. That 22mm nut for that brass line... is connected to the EGR valve.
I would ask though... how does the EGR valve get clogged? Bad PCV system? If you are getting this code, then most likely oil is getting into your intake manifold, throttle body, flametrap, and EGR valve and gumming it all up. If you see this code, and clean your EGR to fix it... chances are the code will come back in 2-3 months.
Old Jul 10, 2011 | 02:16 PM
91shelby's Avatar
or go with a 96 + ecu as they didnt have egr
Old Jul 10, 2011 | 02:54 PM
Mad Matt's Avatar
Win!!!
Old Jul 10, 2011 | 02:56 PM
Hmmmmmmmmmmmmmmmm. So you think I have a plugged PCV system? That's a little strange since I have NO SMOKE coming out of my oil dip stick. Is my system so clogged that it does not let smoke come out of the dipstick? I do think my RMS is leaking.
Psaboic
Jan 18, 2012 10:47 AM
Psaboic
Apr 28, 2010 12:28 AM
Eple
Aug 30, 2008 06:05 PM
BorisRX
Oct 8, 2007 11:27 PM
megatrack
Sep 25, 2007 04:06 AM
