Odd issue on startup.
Old Mar 22, 2011 | 01:57 AM
ibified's Avatar
Default Odd issue on startup.
Lately when I have started my car, the engine revs up to about 3500 rpm and stays there until i put it in gear. When im idling at a light and put it in neutral or park once it has been running, the issue goes away.
Anyone have a clue why it might be doing this?
Oh, and also, another oddity: when i give it a little bit of gas in park or neutral, it will rev up, but when the RPMs drop back down to about 1500, it revs again slightly before dropping back to idle.
Old Mar 22, 2011 | 02:28 AM
Junkyardspecial's Avatar
This happened to me also, when car was cold only. After driving and then having a moment for the car to sit off, it wouldnt do it.
Old Mar 22, 2011 | 10:43 AM
boxpin's Avatar
Air bypass valve staying open?
Old Mar 22, 2011 | 02:30 PM
ibified's Avatar
wouldnt surprise me if that's it. I have a check engine light on, but the only code there is for the O2 sensor. I may just have to break down and swipe another one out of the junk yard. are they the same for the turbo and non turbo?
Old Mar 22, 2011 | 10:23 PM
I would think that idle problem has something to do with the idle control valve. When you start the car, tap it with a screw driver and see if it drops.
On the O2 sensor, I think so. You can check FCP and look at the part numbers.
Old Mar 22, 2011 | 11:23 PM
ibified's Avatar
no i meant are the idle control valves the same for the turbo and non turbo? I have O2 sensors already - just not putting them in until i put on my new turbo and exhaust.
reynolds9000
Jul 6, 2010 04:59 PM
kapka42
Aug 24, 2009 07:53 PM
greg dake
Aug 16, 2009 08:18 PM
shmoo235
May 16, 2009 09:40 PM
greg dake
Nov 30, 2008 06:46 PM
