Odometer motor replacement
Old Nov 17, 2008 | 07:23 AM
cloaker's Avatar
Default Odometer motor replacement
Usual story, the odometer doesn't work - broken gears... OK, I have a spare VDO cluster and take it to a speedo repair guy, he has the gears but rings me up and tells me I have the wrong odo motor - something about mine being a 2 wire and I need a 4 wire. Can anyone tell me if it is possible to find a new replacement odometer motor? I have trolled the internet with no luck. Appreciate any help.
Old Nov 17, 2008 | 08:37 AM
Default RE: Odometer motor replacement
Are you trying to get the spare fixed to swap into your car?
Old Nov 17, 2008 | 08:48 AM
Psaboic's Avatar
Sounds like that is what he is trying to do. I would think it would be easier to simply fix the old cluster.
Old Nov 17, 2008 | 08:53 AM
JPN's Avatar
JPN
+1.
http://www.fcpgroton.com/category-ex...37/by_year/44/
JPN
Old Nov 17, 2008 | 04:52 PM
cloaker's Avatar
Hi tech,
Yes, I want to put the original cluster back in the car but the odo motor is incompatible (or so I'm told). All the links for odo parts are for the gears - what I'm after is just the small electric motor. I know it looks like the proverbial needle but thought I'd at least ask around...
Old Nov 18, 2008 | 06:18 PM
There was like 4 different clusters. Remove yours and replacing the gear then reinstalling would be about the best bet.
Michael Moser
Dec 2, 2021 05:34 AM
jumbo
Oct 3, 2012 07:16 PM
ltrail
Jun 16, 2010 05:01 AM
Kaspir
Aug 8, 2008 02:12 PM
guptash
Dec 24, 2006 11:21 AM
