Oil all over the top of my engine?WTF
Old 12-31-2006 | 07:01 PM
Lukeman's Avatar
Default Oil all over the top of my engine?WTF
well I want to thank the people who have previously answred my posts about some foglight issues that I had, but now I have a more serious problem....
It all started after I took my car to have the rear main seal replaced. It was leaking and it's not any more, I had it fixed by someone who has a lot of volvo experience, and I thought he did a decent job. Ever since then, when I drive the car a little harder, I have oil all over the top of my engine. This guy told me to replace my oil cap and I did, still the same problem, I took the liberty of replacing that nasty oil separator hoping that there might have been excess crank preasure, and i still have the problem. Whats up? I am running out of ideas, I am thinking that I possibly have too much boost (if there is such a thing). and its blowing oil out. I also have this nagging feeling like he might have crossed some oil lines or something.
Any ideas causeI amfresh out.
Old 12-31-2006 | 10:23 PM
Default RE: Oil all over the top of my engine?WTF
Something sounds clogged somewhere. Or the sleeve where the oil cap goes onto the Cam cover is leaking.
Old 12-31-2006 | 10:56 PM
Lukeman's Avatar
I washed my engine and took it out for a quick run. After I cam back the hood was soaked and the rest of of the engine as well. However, i found the leak to be coming from oil dipstick, and a little from the oil cap. Crank over preassure still? I think it's time to do a compression test. i really hope that isn't the problem, because i don't see a lot of blue smoke coming fom the back but something has to be overpressurizing this system
Old 01-01-2007 | 12:02 AM
Check all the little hoses in the system as well.
They replaced the vent box?
Old 01-01-2007 | 12:09 AM
Lukeman's Avatar
Yeah I replaced that ;little black box that sits under the manifold too, if thats what you meanby vent box. I talked to a buddy of mine that happens to be a mechanic at at a Volvo dealership, and he says that they have a tool that measures the vacumm thru the oil dipstick I will try that out and see what they deal is. if thats still the case i will check the PCV system agian and then do a comp test.
Old 01-01-2007 | 12:14 AM
Let me know how it goes.
Old 01-02-2007 | 02:47 AM
Lukeman's Avatar
WellI have good news for me, I couldn't resist so I did the compression test, and the result were okay, well above the minum for 3 cylinders and slightly below on cylinder 3 and 5 but all within the allowable range. I also came to the conclusion that because Volvos are notorious for oil in the intake system, I did a wet compression test too, and found that my valves may not be sealing properly. which is possibly good news. I will do a good engine flush on it tomorrow, and also do a nice oil change as well.
Having said that, probably not expesnive engine work is ncesseary, however, I am back to square one with my crankcase over pressure. So I will use thatvacuum tool tomorrow as well and see if I can find a possible clog in the system.
Old 01-02-2007 | 03:36 AM
JPN's Avatar
JPN
...and it may not hurt to check for blocked exhaust system (a bore scope would be nice, though they are $$$), add a bottle of Techron fuel system cleaner and replace the O-ring on the dipstick.
Best wishes,
JPN
Old 01-03-2007 | 11:34 PM
Lukeman's Avatar
I managed to fix my car! the vacuum tool gave awsome results, the problem was the oil cap itself
Thanx for all the help and support.
Old 01-03-2007 | 11:54 PM
JPN's Avatar
JPN
Good head start for the new year!
JPN
Old 01-03-2007 | 11:56 PM
Congrats!!!
[sm=happy046.gif]
Old 01-24-2010 | 09:01 PM
fireman887's Avatar
Default crank case preasure
u have a vent pluged and the "something or other" value needs replaced . Your crank case is building up to much preasure had the same problem
pacificnw2011
09-05-2010 08:42 PM
conor07
06-29-2010 04:01 PM
HummerGuy
04-25-2009 10:13 AM
Kipp
05-13-2008 10:05 PM
Joe 850 Bird
07-29-2007 12:23 AM
