oil leak
Old Nov 11, 2009 | 03:04 PM
ROBLU540's Avatar
Default oil leak
I have two issues the first one is I have a large leak comming from the passenger side of the engine. The leak is behind the timing belt cover, there is a plastic piece by the tentioner that is wet with oil. It is toward the bottom, What is down there that could be leaking. I will attach a pic.
Second the vehicle is smoking very bad, looks like white smoke, so I am guessing my turbo is going bad, because it is leaking a few drops of oil also.
Any help appreciated.
Old Nov 11, 2009 | 05:19 PM
Carrots's Avatar
That oil leak looks like the front oil pan bolts. The 3 bolts right at that edge are supposed to have thread sealer on them, but many don't from the factory. Volvo has a TSB out on that problem. The way to fix it is this: buy some thread sealer at a parts store, remove one of the bolts, clean it thoroughly, coat it with sealer, reinstall, torquing it to spec. Repeat with the other 2. Only remove and replace one bolt at a time, to prevent breaking the oil pan seal.
As for the white smoke, there's lots of things that can cause that. A few drops of oil from a turbo is normal... a lot of oil isn't. The first place I'd check is the PCV system. Start your engine while it's cold, then remove the dipstick. Do you see clouds of smoke coming from it? if yes, you likely need a PCV system replacement, details can be found with a search of the forum. Another way to check this is by putting a balloon over the dipstick tube, and seeing if it inflates. If it does, there's pressure building up in the engine, which indicates a plugged PCV system.
Old Nov 11, 2009 | 05:32 PM
gilber33's Avatar
I think I have that same leak on the motor I have for my wagon, except it's not all the way behind the timing belt cover, it's like inside of it.
Old Sep 7, 2010 | 11:22 AM
cordel7's Avatar
i have a Volvo 850 glt with the same problem i have crank case pressure instead of vacuum and oil is on the passenger side of the chassis on the CV boot and all over the passenger side of the car i know my PVC system needs to be replaced but anything else anyone can guess
Old Sep 7, 2010 | 11:43 AM
ibified's Avatar
if it's inside the timing cover, it's probably the front crank seal. Not hard to do, if you happen to be doing a timing belt at the same time. And if you're gonna replace the front crank seal, you may as well do the timing belt anyway, because you're gonna have to remove it to get to that seal.
Old Aug 23, 2011 | 05:42 PM
cordel7's Avatar
i have a question as anyone made a supercharger for the volvo 850 or have anyone bolted one on
Old Aug 23, 2011 | 11:35 PM
vjaneczko's Avatar
Never heard of anyone adding a supercharger, just increasing the size of the turbos. It'd be interesting if it could even be done. I'd think you'd have to reprogram the ECU (all by yourself) and change a bunch of other stuff.
A lot of people ask if they can add a turbo to their NA, but it's cheaper and easier to just buy a turbo's version from the factory. I can only think that the supercharger idea only cranks up the headaches.
ROBLU540
Feb 20, 2009 07:59 PM
mkelly85
Jan 31, 2008 02:05 AM
pleonard
Jan 7, 2008 06:12 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
