Video-why you no start?
Old Aug 23, 2011 | 01:10 PM
Media's Avatar
Default Video-why you no start?
No start - YouTube
Hello.
I am more of a tinkerer than a mechanic, soI feel a bit foolish forgetting something that would seem obvious.
I read through lots of vague posts here and there about what may be wrong here. I figured it's 2011, I could just stop the guess work, and post this video on the forum.
Bottom line, car will not turn over.
Fuel - check
Power - check
Spark - Good as far as I can tell.
Belts - check
Fuses- check
Vacuum - Fittings/hoses checked, no visible problems.
What I think?
I have a feeling it is electrical, or a bad fuel pump. I am more than a little rusty. So, I will leave it to people a tad more in the know.
If you have any ideas, I am all ears.
Thank you.
Old Aug 24, 2011 | 12:12 AM
gdog's Avatar
Originally Posted by Media
No start - YouTube
Hello.
Fuel - check
Power - check
Belts - check
Fuses- check
Vacuum -Fittings/hoses checked, no visible problems.
What I think?
Thank you.
FYI: the engine is turning over (aka cranking over); it's just not starting.
And you barely cranked it long enough to start; suspect you've been doing that awhile since the battery sounded low (state of charge). Put a trickle charger on it for 12 to 24 hrs.
Some background info would be helpful; did it just die going down the road, not start one morning, been dying periodically, or what??
Did you hear mechanical noises when it stopped (e.g. a timing belt letting go)? Compression test would confirm if that's an issue or not.
Most likely I suspect you don't have any fuel pressure; did you ck? If that's the issue ck here for more suggestions; most likely Fuel Pump Relay or Fuel Pump.
BTW: yellow text is almost impossible to read.
nicolas414
Oct 9, 2024 12:53 PM
fabivolvo
Dec 20, 2015 11:50 PM
schigara
Nov 27, 2009 10:39 AM
VOLVO15
Sep 21, 2009 04:51 PM
jdseattle
Dec 31, 2008 08:04 AM
