oil leak
Old Jan 16, 2010 | 09:42 PM
radio16's Avatar
Default oil leak
i found my oil leak finally - its coming from a small metal plate on the back of the engine- RIGHT BELOW the turbo - its held on by 4 bolts, and under the plate is what appears to be a small rod witH a hole and spring system in it - i took the plate off and wiggled the piece out - it was coated with varnish and stuck - i assume it has someting to do with oil pressure - any chance anyone knows what it is ?? and what it does - and its name - i cant seem to find any images of it any where-it needs a new gasket
THANKS
ROBLU540
Feb 20, 2009 07:59 PM
mkelly85
Jan 31, 2008 02:05 AM
pleonard
Jan 7, 2008 06:12 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
