oil leak on the back of engine drivers side
Old Oct 7, 2008 | 07:49 PM
vetalbig's Avatar
Default oil leak on the back of engine drivers side
hi! i've got an oil leak on the back of my engine, i have "95 850 turbo,
so there is a mettal tube(i guess it is an oil return line) approx. in the middle of enginethat goes into the block there is some oil coming out from there and there is another place thati dont know where it can leak from in that area because it is hard to see it's somewherebetween cam sensor and turbo.
my main question is how to change theseal on theoil return line, howactually i need toget that tube out of the engine block?
thanks a lot to every body for your time.
Old Oct 7, 2008 | 08:11 PM
Default RE: oil leak on the back of engine drivers side
You have to unscrew the pipe from the turbo and work it out.
I would replace that first and clean everything then go from there.
Old Oct 7, 2008 | 08:15 PM
vetalbig's Avatar
thanks tech,
yeah i think it might just throw oil everywhere from there.
i will do as you sad.
thanks again.
Old Oct 7, 2008 | 08:18 PM
When that seal goes bad yes it will shoot it all over.
Old Oct 8, 2008 | 07:45 PM
vetalbig's Avatar
thanks for your time tech,
one more question is this the gasket that i'm looking for?
http://www.fcpgroton.com/product-exe...ategory_id/125
Old Oct 8, 2008 | 08:54 PM
The ones you need are in that kit but here they are seperate.
http://www.fcpgroton.com/product-exe...ategory_id/218
I don't see that they sell them in a kit without buying the kit to remove and replace the oil pan.
Old Oct 21, 2008 | 08:32 PM
vetalbig's Avatar
oh man!
finaly fixed it.
the oil was coming out of thecam sensor, the leak was bad,
the biggest problem was to find it and than i just sealed it which took me like 25 min.
the oil return line was leaking a bit too.
thanks tech!
Old Oct 22, 2008 | 07:34 AM
Glad you found and fixed it.
mafraziersr
2001-2013 model year V70
May 30, 2015 04:10 AM
James Ira
Sep 23, 2010 08:28 PM
ToledoVolvo01
Apr 30, 2010 09:34 PM
Bruce Wayne
Jan 2, 2009 01:45 AM
kartman01
Nov 26, 2005 09:47 AM
