oil on top of head
Old May 9, 2007 | 09:38 AM
pollock's Avatar
Default oil on top of head
What would cause oil to pool on top of the head?
It's always there. I've replaced the crankcase vent box and all the related hoses.
'96 850 turbo.
Old May 9, 2007 | 09:51 AM
JPN's Avatar
JPN
Default RE: oil on top of head
Hello Pollock,
Oil on top of the head is one of the chronic problems to 850s. The oil filler cap gasket is of poor quality and as far as my 850 was concerned, I had to replace it at every other oil change. Another source is the dipstick O-ring, but this one is located below the top of the head, so I assume it's the cap gasket. However, one person has reported that he had a crack in the filler neck (according to him, the filler neck turned a bit as he tightened the cap), and he managed to repair it with JB Weld. The worst case scenario is probably something like this, as the head is aluminum and certain locations are made very thin so they could develop cracks.
I would wipe clean the oil, replace the cap gasket and see what happens. In the meantime, I believe other people would be able to jump in and provide you with other solutions that I may be missing at the moment.
Good luck,
JPN
Old May 9, 2007 | 12:01 PM
mauriciogalvao's Avatar
Agree with JPN. Change the rubbergasket or the entire filler cap. Agree also that no matter what, every now and then we have to change it. Definitely is of poor craftsmanship.
Old May 10, 2007 | 09:00 AM
Psaboic's Avatar
I had the same issue and as mentioned by others, I changed the oil cap gasket and it cured the problem. I now make it a point to change the gasket at every other oil change. FCP Groton has them for about $2
Old May 10, 2007 | 11:43 AM
JimKW's Avatar
I've changed that gasket once in 22 years of owning Volvo's. And that was just last month on the one I just bought. I just don't get it.
Old May 11, 2007 | 10:23 AM
pollock's Avatar
It doesn't seem like that gasket should HAVE to seal the oil in. Seems like it was intended more to keep dirt out.
Old May 11, 2007 | 10:01 PM
JPN's Avatar
JPN
You may be right, I don't know of any other vehicle that has so much leak from oil filler cap. It may only be cured by servicing the PCV related components. I am also suspecting the cap itself; it is of peculiar design and it seems to have spring (?) mechanism to it as you see a "cross" type metal tangs (it may only be there forpositioning purpose). If it still leaks after doing a complete PCV system servicing, the lastresort would be to wait for Tech's reply or call the engineering dept in Sweden[8D].
JPN
Quick Dent
Jan 15, 2012 08:50 PM
mr_noche
Nov 8, 2010 12:33 PM
pacificnw2011
Sep 5, 2010 07:42 PM
propup
Aug 3, 2010 03:05 PM
propup
Jul 16, 2010 03:35 PM
