P/S return hose fix?
Old Mar 1, 2011 | 09:11 PM
skipv's Avatar
Default P/S return hose fix?
The return hose is leaking at the crimp connection. Since it is low pressure can I cut off the crimp and use a new piece of hose and clamp?
Old Mar 1, 2011 | 09:28 PM
Henry10's Avatar
Yes. But you need to use "Power Steering Return Hose" and 2 clamps. The trick is to find the hose with the same inside-diameter as the steel line outside-diameter. You can also use transmission cooler hose or oil cooler hose. Whichever hose should be rated for at least 250-300 psi.
You should cut back to the steel tube, (i.e. remove the crimp) and insert the rubber hose at least 3 inches over the steel tube. On the other end the new hose should be clamped into the P/S pump.
drenman
Nov 29, 2016 07:35 AM
Ricardobs84
Jun 22, 2013 09:46 PM
I8ASaleen
Apr 8, 2011 12:20 AM
theotherpilot
Jul 10, 2009 12:28 AM
Volvorator
Mar 15, 2007 10:37 AM
