Broke a radiator hose neck. Any fix?
Old Mar 7, 2011 | 09:12 AM
I8ASaleen's Avatar
Default Broke a radiator hose neck. Any fix?
Ok so I was replacing the radiator hose on the driver's side coming from the thermostat. Puting the hose in the neck and it just snapped off clean, does anyone know a way to fix this?
I have seen someone take a butane torch and a zip tie and plastic sauter part of the radiator together, anyone heard of this?
Old Mar 7, 2011 | 02:05 PM
Is that on the radiator or hose on the t-stat housing? If it's the radiator, count your blessings and get a new radiator. That thing was ready to blow and you found it where you could deal with it instead of on the road somewhere.
Old Mar 7, 2011 | 07:32 PM
I8ASaleen's Avatar
Yea it was on the radiator. They put a metal sleeve inside of the hose neck and it snapped off right where the sleeve ended.
Old Mar 10, 2011 | 07:33 AM
texyTodePoexy's Avatar
Default coach handbags
Wow, that looks so great!Perhaps you have had changed the concept not long ago? Due to the fact I could have got sworn it was not exactly the same the prior time I had been here?-unless I am thinking about another site. air jordan mall Nike Air Max LTD Jordan Fusion 6 Air Jordan 14 (XIV) Air Jordan 2010 Enfants Nike Air Max BW Nike Air Max 97 Recently, I did not provide a lots of consideration to be able to offering comments on-site page content articles and possess situated comments actually less.
Old Apr 8, 2011 | 12:20 AM
wyobear's Avatar
Smile Radiator repair/replacement
Any fix for a broken neck...to fix it the correct way, you are right...replace it. I just had to replace the radiator on my S90. I thought this was going to be expensive, but located a new one at a local shop so the bill was only $155.00! It was an exact fix and only took me a few hours to do.(Ya, I'm slow) Just about all radiators have plastic end caps, so don't over tighten or stress the fittings. Going into another hot Nevada summer I will be glad I did the replacement rather than getting caught on the road somewhere!
mikeawd850
Nov 30, 2012 02:26 AM
skipv
Mar 2, 2011 10:39 PM
nathancarter
Jun 3, 2010 01:05 AM
RedTurbo850
Feb 20, 2007 12:32 AM
designstate
Oct 31, 2005 11:31 AM
