Parking Brake Adjustment
How do I adust the park brake on a 95 850 turbo SW? I read the manual but it does not tell you what type of tool is used to tighten the brakes. In addition I cannot find the tightning screw thru the disk. I tightened the hand brake lever in the car but that was not enough. Thanks
RE: Parking Brake Adjustment
An excerpt from a "trustworthy" publication:
1) Remove rear wheels. Rotate disc until adjustment hole is directly over adjustment screw between brake shoes. Adjust brake shoes by turning adjustment screw upward until brake disc can no longer be rotated. Adjust shoes by backing off screw 5 notches.
2) If there is play between cable & lever, fine adjustment can be made at parking lever. Full parking is achieved between 2-8 clicks.
Good luck,
JPN
Good luck,
JPN
I8ASaleen
01-03-2017 10:01 AM
Wood-Bee-Mechanic
2001-2013 model year XC70
05-11-2012 01:15 AM
