Passenger (Left Hand) Wing Fitting
Old Jul 15, 2007 | 12:47 PM
mitchell00001's Avatar
Default Passenger (Left Hand) Wing Fitting
Hi
Newbie to this so hi to all. Hope that someone out there can help with a couple of problems I have with my T5.
1.
Does anyone have fitting instructions for fitting a front wing to the car. I have checked my Haynes manual and its not covered and now that I have a wing to replace the one on there I want to get it done as soon as....
2.
Poor acceleration and power. Been like this since I bought the car. Have checked the compression on the pistons and valves and they are all at 12 bar (180psi) soI think there may be an issue with the turbo. Are there any checks I should be making on it or any of the hoses going to from it. To help along, the symptoms are:- low power and poor acceleration, over reving by 500-1000 rpms when changing gear, power doesnt drop off immediately when you come off the throttle (worse when the a/c is on). No blue smoke at either idle or over run so don't think that the turbo has failed itself, just something controling it maybe....
Many thanks in advance to anyone who can help.
Old Jul 15, 2007 | 04:29 PM
JPN's Avatar
JPN
Default RE: Passenger (Left Hand) Wing Fitting
Hello mate,
Welcome to the forum.
As to your first question, did you mean the front air dam/chin spoiler that goes under the bumper? I am a bit puzzled.
As to the 2nd question, the following thread may give you some ideas:
https://volvoforums.com/m_64263/tm.htm
Also, wait a bit if you can till other members reply; there are quite a few experts in the 850 forum and someone will be here shortly I believe.
Cheers,
JPN
Old Jul 16, 2007 | 07:34 AM
Hi
Thanks for the reply, will; check out the thread shortly.
As to the wing, it is the actual front wing of the car where the wheel is. I know that they are bolt on but am not sure of the bumper has top be removed first.
Many thanks
Mitch
Old Jul 16, 2007 | 01:20 PM
J Telectro's Avatar
Fender????
Or bumper bracket/ reinforcement????
Best regards, John
Volvo_User
Nov 26, 2014 02:42 PM
brians60
Dec 18, 2010 07:33 AM
nicolaselias
Feb 28, 2008 08:23 PM
arb173
Jan 31, 2006 10:04 PM
azeezn
Nov 20, 2005 10:38 PM
