Petcock valve removal
Old Apr 8, 2009 | 09:24 AM
dlaxdal's Avatar
Default Petcock valve removal
Does anyone have any tips on how to remove a broken plastic petcock valve off the radiator on a 850 turbo. It is broken flush with the insert. Love the plastic on the cars!!!!!!!
Old Apr 8, 2009 | 07:22 PM
Use an easy out.
Old Apr 8, 2009 | 08:24 PM
Johnny Mullet's Avatar
If you need to drain the system, yank the lower hose. Mine broke and is gonna stay broke.
Old Apr 9, 2009 | 08:09 AM
dlaxdal's Avatar
what is an easy out?
Old Apr 9, 2009 | 08:27 AM
Psaboic's Avatar
Also called a bolt removal tool. Basically it is a reverse drill bit, as you turn it, it bites into the broken part (bolt, screw, etc) and backs it out
Old Apr 10, 2009 | 09:27 AM
dlaxdal's Avatar
Default petco
I got a new one and I think you should be able to use a small screw driver and it should be able to grab what is left up in the radiator
Old Apr 10, 2009 | 02:25 PM
JimKW's Avatar
Don't mess up the threads!
jefhon
May 7, 2018 06:17 PM
RA082324
Dec 28, 2014 08:32 AM
haircuttingcow
Sep 12, 2013 10:19 PM
fixedgearhead
Aug 29, 2013 10:25 PM
RedTurbo850
Feb 20, 2007 12:32 AM
