Power steering/coolant flush is it necessary
Old Nov 11, 2008 | 09:53 AM
tjmm1335's Avatar
Default Power steering/coolant flush is it necessary
I have a 1996 volvo 850 with 185,000 miles on it. I was wondering if it is necessary to get a power steering flush and a coolant flush. Many places I called getting a price said that it is not necessary unless it is leaking or bad. What should i do.
Old Nov 11, 2008 | 09:57 AM
Default RE: Power steering/coolant flush is it necessary
You can get it done.
The coolant usually gets done every 30K but the steering there is really no interval.
Old Nov 11, 2008 | 10:27 AM
tjmm1335's Avatar
How should the coolant flush be done? Many places I called said that using the machine could cause debris in the tank to get pushed and cause a clog, and other places said that they just drain, fill, drain and refill again so they dont cause damage. What do you think. I dont want to pay more for a problem that wasnt there.
Old Nov 11, 2008 | 11:14 AM
Drain and refill it thats the best way to do it.
Old Nov 13, 2008 | 02:52 AM
ShaginWagon's Avatar
I've drained and refilled my power steering with castrol transmax z (for auto's) and the difference was amazing.
Just sucked out what I could from the reseviour, topped it up with new fluid, started and turned full lock one way, sucked out, topped up again, full lock other way and so on.
Old Nov 13, 2008 | 09:52 AM
JPN's Avatar
JPN
I do the coolant at every 30,000 miles or 3 years. Drain & refill with 50:50 mix (some regions may require different solution).
As to PWS fluid, I leave it unless it is leaking. The PWS fluid is Dexron-III/Mercon; exactly the same fluid used for the tranny.
JPN
Old Apr 9, 2009 | 09:07 PM
tmixdorf's Avatar
Shaginwagon,
My power steering seems to get "rough" every 2 weeks. I put power steering fluid in it and the 1st time it took a whole bottle, 2nd time, 3/4 and the 3rd time about the same. It runs great after about 10 minutes of me driving around and then as stated above, within 2 weeks, I hear that grinding/humming sound and I know I need to do this again.
My question is this:
Where did you get what you used on your power steering and
Do I need to STOP using power steering fluid OR
is there a stop leak product I can use to help curb this.
I'm in IA and it has been a LONG and COLD winter, so I haven't been able to see anything from the top leaking.
Thank you
patrm
2001-2013 model year V70
23
Mar 5, 2014 08:43 PM
shop2
Nov 1, 2011 08:56 AM
mowntnbkr
Aug 15, 2011 08:17 PM
nicolaselias
Mar 24, 2011 08:48 PM
Glenn B
Feb 19, 2008 04:57 PM
