power steering pump noise
guys l need your opinion on what you think could be wrong with my steering pump. on cold starts it makes this squeaking noise but stops the squeaks when it warms up. here is a video of it. thank you
volvo 850 R power steering pump noise - YouTube
Maybe it's my speakers but I'm not really hearing a squeak. You can try dripping water on the serpentine belt to see if it goes away. It's a bit messy as it does sling it everywhere but if your squeak stops than you know it's the belt. If the belt still looks good you can mark it with a crayon and reverse it's direction. If not, then you just replace the belt.
RSPI, what rythematic noise is that? my timing is very much on time.will a wrong timing cause noise? l hear a sound like a bearing noise near the timing belt cover when its warm and l learnt that its the water pump bearing. when the radiator fan turns on that noise stops but comes back when the fan shuts off after cooling.l will take another video in the morning and post it up tomorrow.
RSPI, tell me if you hear any strange sound in this video.it sounds normal to me.this is when it was warmed up.thanks
volvo 850 R - YouTube
I'm sorry but IMHO it's going to take a lot longer than that. It's not that hard but it's likely one to two hours depending on your tools. The hard part for me was messing with the tensioner that had a dedicated tool to take the tension off the belt. I finally bought a new tensioner that uses a regular 1/2" drive breaker bar in a 1/2" hole on the arm.
http://www.matthewsvolvosite.com/for...le.php?id=3735
http://www.matthewsvolvosite.com/for...hp?f=1&t=27049
Have you found the source of the noise yet ??
Really ?? Replaced the pump in 10 min ,,, really ??
albmm05
01-04-2009 01:07 AM
katiejoyful
12-12-2007 04:49 PM
