prblems after changing automatic gearbox with mechanic
Old Apr 25, 2008 | 02:47 PM
levantab's Avatar
Default prblems after changing automatic gearbox with mechanic
Volvo 850 GLT`1993 with Automatic transmission (AW 50-42LE). I have changed automatic gearbox with mechanic. After this change occurs following type of problems 1. Engine runs abnormally with idle and middle wheel. 2. Diagnostic unit shows several errors: 3-1-4 and 2-1-4 at the same time all the sensors are OK. Can you give me some advices how to fix this problem?
Old Apr 25, 2008 | 07:09 PM
Default RE: prblems after changing automatic gearbox with mechanic
Are you sure it is a 1993 tranny they installed?
It has to be a 1993 tranny only.
Old Apr 26, 2008 | 02:07 AM
levantab's Avatar
I am not sure if it is 1993 tranny or not. I did not have much choice and in case it is not , can I fix it now? Should I change fly-weel, ECU or Ignition Unit?
Old Apr 26, 2008 | 07:54 AM
I believe it is something with the sensors on the tranny.
Old Apr 26, 2008 | 03:42 PM
levantab's Avatar
One more interesting thing: when I switch off the Mass Airflow Meter, it seem the engine runs normally, also I tried to install several types of Mass Airflow Meters but problem wasn’t solved
Old Apr 26, 2008 | 04:10 PM
Unplugging the mass flow won't kill the car that is normal.
A massflow sensor will not fix a tranny problem.
volvo no go
Jan 21, 2012 09:24 PM
TEQUILA
Feb 6, 2010 04:03 PM
thewolf
Mar 24, 2009 03:07 PM
witgrefe
Jul 3, 2008 12:35 AM
Nicholunch
Jan 30, 2006 04:47 PM
