pulling/instablity under braking
Old Jun 9, 2009 | 01:09 PM
aegir71's Avatar
Default pulling/instablity under braking
Hi there,recently bought a 96 850 which is in all round good condition but has a tendency to pull to the right in particular and feel generally unstable under braking.I have been told that this may be due to worn bushes in the wishbones,is this the likely culprit? The brakes,pads,discs all appear in good condition.
Old Jun 9, 2009 | 01:25 PM
850tony's Avatar
what wishbones are you talking about? the control arms?
sounds like its just a simple sticky caliper
Old Jun 9, 2009 | 01:59 PM
aegir71's Avatar
Hi, I meant the front lower wishbones,there may be a difference in terminology as I'm in the U.K. I don't think its a stuck caliper as the reaction is not consistent at all speeds
Old Jun 9, 2009 | 02:07 PM
850tony's Avatar
i think you are talking about a control arm. and in that case you would prolly be feeling a clunk of some sort... or hearing one for that matter. could be a ball joint maybe? or a strut mount?
Old Jun 10, 2009 | 03:29 PM
bitter356's Avatar
Check your rubber brake hoses. If they show signs of dry rot, replace them.
Old Jun 10, 2009 | 04:07 PM
bestharry's Avatar
Bushings on controller arms.....they are fairly common to go bad and then the arm can swing a little bit without making any clunks but still enough to make the car pull to one side. I had that with my sedan when i bought it and replacing both arms and one broken spring seat in front strut fixed the problem....Also rotate the tires and see if makes any difference?
sgreenfield
Aug 17, 2012 08:45 AM
TomT
Aug 7, 2011 06:45 PM
itsmy850
May 3, 2011 05:44 AM
tbenner
Jul 11, 2007 06:24 AM
scottbr997
Feb 26, 2007 12:35 AM
