Pulsed Secondary Air Injector Pump.
Old Mar 15, 2013 | 01:50 PM
raybun's Avatar
Default Pulsed Secondary Air Injector Pump.
The air pump in the secondary air injection system on my Grandsons 850 has died. The pump had picked up water from an unknown source. We checked in local salvage yards and every pump also had water. A new pump is very big bucks. Can an otherwise functioning pump be used if the water is blown out by intermittent running with a car battery?
Thanks Ray & Grandson
Old Mar 15, 2013 | 02:40 PM
MattyXXL's Avatar
The sas pump is pointless, once that check valve goes bad your stuck. There is no point to replace it just remove it.
There is a procedure to removing it and running with out it found here
http://www.matthewsvolvosite.com/for...hp?f=1&t=31536
once the jumper diode has meen installed you can remove the entire sas system. You will just have to get a upper air box cover that does not have the sas port inlet on it.
Old Mar 15, 2013 | 04:10 PM
Unless you need it for an emissions inspection ...
Might find one a little cheaper on rockauto.com
Or someone might be able to snag a used one at their local yard if you didn't mind paying plus postage ?? Wouldn't hurt to ask if you needed or wanted to retain the system.
Old Mar 15, 2013 | 06:48 PM
MattyXXL's Avatar
sas doesnt count for inspection.. EGR does but not sas..
If it passes in Cali it will pass everywhere
Old Mar 15, 2013 | 08:08 PM
ES6T's Avatar
In some states, anything that sets a check engine light will fail it for emissions. In which case, it would need to be repaired.
Old Mar 15, 2013 | 08:18 PM
MattyXXL's Avatar
If you bothered to look at the link you would notice that soldering in the diode stops the CEL..
I was talking about visual inspection, no state is going to look for a sas pump.
Old Mar 15, 2013 | 09:36 PM
ES6T's Avatar
Well then you're right, I didn't click the link
patarack
Nov 23, 2011 11:03 PM
jeff71
May 14, 2011 09:57 PM
sohcfour
Apr 28, 2010 07:34 PM
heybuddy
Mar 2, 2009 08:12 PM
dece207
May 3, 2005 09:49 PM
