pump replacement
Old Oct 18, 2006 | 10:09 PM
hugoa's Avatar
Default pump replacement
I have to replace my fuel pump on my 95 850 sedan non turbo. I found just the pump for $165 w/out any brackets or hardware. once i remove the factory one can i use the original brackets to put the new one in? If so what else would I need?
All info or thoughts are greatly appreciated.
Thanks in advanced
Hugo adames
Old Oct 20, 2006 | 02:14 PM
code33's Avatar
Default RE: pump replacement
Save about $90 and get this one:
http://www.fuel-pumps.net/fuel-pumps...cyl--2-4l.html
The pump is made by Walbro, a good company.
Yes, the pumps sits inside a housing that gets dropped into the tank. You reuse this. There's a gasket at the top of the housing that I would suggest replacing.
turboxr
Dec 17, 2011 12:35 AM
spidersilva
Aug 17, 2011 07:23 PM
scrap88
Apr 7, 2010 09:23 PM
montysano
Sep 9, 2008 11:52 AM
katiejoyful
Dec 12, 2007 04:49 PM
