Timing Belt replacement...When?
Old Oct 18, 2006 | 10:26 AM
jtvrba's Avatar
Default Timing Belt replacement...When?
I own a 1995 850 wagon w/115,000 mile on it. I started to have oil leaks so I:
Threw away the spark arrestor, installed a new intake hose (cracked), Replaced the plugs, and replaced the oil fill cap,
and the top engine mount. And I'd like to know if I NEED to replace the timing belt?
At what mileage should the belt be changed?
Also are there any other items I should check/replace?
Any input would be welcome.
Old Oct 18, 2006 | 01:12 PM
info2x's Avatar
Default RE: Timing Belt replacement...When?
Timing belts MUST be replaced every 70,000. These are interferance engines which means if that belt breaks your looking a one huge bill.
Old Oct 18, 2006 | 04:02 PM
code33's Avatar
+1
Get timing belt changed ASAP; you are way overdue.
Do the PCV system too. Excessive crankcase pressure can cause leaks.
Old Oct 18, 2006 | 04:08 PM
JimKW's Avatar
That's assuming it wasn't changed at around 70K. I kind of doubt you got to 115K on an 11 year old car w/o have the timing belt changed at least once. If it hasn't been changed once, I wouldn't even drive it again w/o having it changed. I think it's called for every 70K or five years whichever comes first.
Old Oct 20, 2006 | 06:17 PM
cranky's Avatar
JFTR
The 93 850's are supposed to be changed every 50k or 60, I can't remember right off - but its more often than the others.
Cranky
Old Oct 20, 2006 | 07:25 PM
RedTurbo850's Avatar
If you're timing belt breaks, you will need a complete rebuild which si going to easily cost over $$1000.
Old Oct 20, 2006 | 07:27 PM
billofdurham's Avatar
92 & 93 models belt change at 50,000 or 5 years.
04v70
Jul 17, 2009 11:01 AM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
