Question about replacing springs
Old Oct 3, 2007 | 12:56 AM
outblast's Avatar
Default Question about replacing springs
CanI put rear 854R (i think there sedan springs on my 96 850r wagon heres the ones im thnking about buying http://cgi.ebay.com/ebaymotors/Volvo...QQcmdZViewItem
Thank you for your inputbecause im buying them soon one of the rear ones is saging badly
Old Oct 4, 2007 | 02:15 AM
JPN's Avatar
JPN
Default RE: Question about replacing springs
Hi,
Sagging problem is usually caused by faulty/deteriorated dampers (struts/shocks) therefore you may want to replace the rear shocks.New/mod coil springs give you firmer ride (same goes for dampers), and unless the springs are physically broken, you may not cure the sagging problem by replacing the coil springs.
I would consider replacing the rear shocks, with either the OEM (Sachs) or Bilstein Touring. Here's a good vendor many of us here use:
http://www.fcpgroton.com/volvo.htm#850
I hope this is of some use.
JPN
Old Dec 20, 2007 | 07:27 PM
outblast's Avatar
Thanks! I just ordered2 rearBilstein Touring shocks that you recomended. Ill let you know if they solve the problem when i get them installed. (have to figure out how to install them now)
Old Dec 20, 2007 | 07:45 PM
RedTurbo850's Avatar
The suspension is only compatible for the fronts between the 854 and 855.
Old Dec 20, 2007 | 09:48 PM
outblast's Avatar
thats to bad becauseI really like the company, Ipdusa, I've heard nothing but good things.
Edit** I've decided to replace all the shocks. The factory ones in the rear are the self adjusting ride height type, im afraid if i replace them with regular shocks the car might be to low due to the already low 850R springs. Hmm, any sugestions?
Old Dec 20, 2007 | 09:49 PM
IPD is rediculously overpriced.
Old Dec 20, 2007 | 09:53 PM
outblast's Avatar
True, any comment on the edit above?
Old Dec 20, 2007 | 10:53 PM
ORIGINAL: outblast
Um......Did you order stuff already then?
Because there are two struts in the front.
2 shocks in the rear.
To tell you the truth, I am not familiar with the nivomats. I would suggest a search and see if you can find out what's bad about replacing nivomats with non-nivomat (maybe they don't fit??, I'm not sure).
Or just wait until someoen who knows chimes in.
Old Dec 21, 2007 | 12:37 AM
JPN's Avatar
JPN
If your car came with Nivomats then I would go with Nivomats but only after verifying that they are failing.
http://www.fcpgroton.com/volvo850shocks.htm
The listed price is $305[:@]!!! They'd better come as a pair!!!
I would wait to hear from Tech, to see what he thinks.
Happy holidays,
JPN
Old Dec 21, 2007 | 01:37 PM
outblast's Avatar
whoh, i can get sporty suspention for that price, ouch. I was hoping i could just replace the mounts to fit regualar type but im not sure..
westmain
Jun 15, 2011 07:56 PM
cdurnal
Nov 3, 2008 11:33 PM
yamarx1
Jul 31, 2008 07:49 AM
kh0007
Mar 17, 2008 09:16 PM
user 4657673
Nov 29, 2007 06:22 PM
