Question about windows & sunroof button
Old Mar 15, 2009 | 02:13 AM
Arsenal6's Avatar
Default Question about windows & sunroof button
Hey guys I was have windows, sunroof and heated seat problems.
For some reason the passenger window doesn't work when it cold...and it stutters when it warm doesn't move smoothly.
One of those nights I opened the passenger window and wouldn't closed I tried a blow dryer on the button and it worked instantly...I was wondering could that be whats affecting the rest of the stuff?
My heated seats light come on but it never warms up...and the sunroof u can heat the click but thats it.
Any ideas?
Old Mar 15, 2009 | 07:26 AM
The window and sunroof switches might be bad.
The seat heaters there might be a wire under the seat bad.
Old Mar 15, 2009 | 01:13 PM
Arsenal6's Avatar
Thanks for your insight
is there a way i can check before I start purchasing new switches and replacing them?
Old Mar 15, 2009 | 03:56 PM
It will be a little bit of a pain but you should be able to test them with an Ohm meter.
Old Mar 15, 2009 | 06:52 PM
Arsenal6's Avatar
Where would i plug the ends to? The fuse box area...well the sunroof there trying of movement there when i click the button doesn't that mean a current is going through?
Old Mar 17, 2009 | 07:37 PM
If you can hear the motor clicking then something else is wrong.
You will have to play with connecting the probes. But you will be testing to make sure current flows through.
Incursus
Jan 2, 2014 12:30 PM
mjohnny
Mar 18, 2013 02:35 PM
schmuecker
May 19, 2011 06:45 PM
robyr
Dec 12, 2010 10:45 PM
davidschaffer
May 29, 2010 04:48 PM
