Question bout Catalytic converter
Old Nov 7, 2008 | 07:46 PM
Arsenal6's Avatar
Default Question bout Catalytic converter
yeah my volvo is kinda having some problems, the dad wants to get a new front pipe for the catalytic converter behind the firewall...volvo says it 1 piece. Costing me 1294 + 80 for bolts if i want it, I was wondering where can i find a used one for cheap?
Old Nov 7, 2008 | 07:51 PM
Default RE: Question bout Catalytic converter
Most states it is illegal to seel a used one.
You might be able to find one.
Also check FCPgroton.com
It is possible the cat is clogged or coming apart and blocking the pipe. Did you hear rattling when the car was at idle?
Old Nov 7, 2008 | 08:04 PM
TIPSP's Avatar
Got Boost?
Well...You can always do a custom pipe/cat at a local shop...or just have them weld a new cat.
IPD, EST, VIVA preformance, andmaybe some more people have high preformance pipes/cats for like $700-$800.
Just thought I would throw those options out there.
Old Nov 7, 2008 | 08:06 PM
Also remember if you go that route it will make it slightly louder.
Old Nov 7, 2008 | 08:28 PM
ShaginWagon's Avatar
Don't know if this applies to other countries, but in Australia the cat has a small resonator in it.
Apparently it makes quite a difference to exhaust noise.
Guy that did my exhaust should know, he has an 850 himself.
After a lot of research he recons the cat assy from a mercedes fits, has the resonator built in, and is cheaper..
Old Nov 7, 2008 | 10:15 PM
JPN's Avatar
JPN
Turbo 93:
n/a93:
http://www.fcpgroton.com/category-ex...136/by_year/43
Turbo 94-95:
http://www.fcpgroton.com/category-ex...137/by_year/44
n/a 94-95:
http://www.fcpgroton.com/category-ex...136/by_year/45
Turbo 96-97:
http://www.fcpgroton.com/category-ex...37/by_year/46/
n/a 96-97:
http://www.fcpgroton.com/category-ex...136/by_year/46
All seems under $400. Contact FCP Groton for bolts/hardware availability. Also try searching at: http://www.eeuroparts.com/Main/Home.aspx
I personally do not like used exhaust components.
JPN
Old Nov 8, 2008 | 01:08 AM
Arsenal6's Avatar
it a non-turbo 96 GLE, i did have some rattling before the car started having real problems, after leaving it alone for a hr it is louder than a muscle car
Old Nov 8, 2008 | 02:56 AM
JPN's Avatar
JPN
It may have developed a leak somewhere in the exhaust pipe. I would visually inspect the entire line while the engine is stone cold. The closer the leak to the engine, the louder it is.
JPN
Counselor828
Feb 28, 2011 07:04 PM
chadwilson
Feb 15, 2009 11:39 PM
knight rider
Sep 17, 2005 05:26 PM
carlo
May 20, 2005 11:35 PM
carlo
May 11, 2005 04:28 PM
