Question + I saw a non turbo spit fire from the exhaust
Old Dec 4, 2008 | 08:14 PM
Aopocetx's Avatar
Default Question + I saw a non turbo spit fire from the exhaust
I have an 850 just like the one I saw except that one was a wagon. But his was an SLT - what's the difference? This guy was cruising and I saw him floor it and he took off. Personally my 850 has about 190 HP right now but this dude was shooting fire from his exhaust! So my question is, does it shoot fire simply because of how much power that car has? If so, how much HP does it take to do that? Because I want to build a racing non-turbo 850. Already did a stage 0 tune plus magnaflow catback.
Old Dec 4, 2008 | 09:23 PM
Default RE: Question + I saw a non turbo spit fire from the exhaust
Usually cars that can do that are set to run really rich and are able to run at a high RPM to be able to shoot fire like that.
They are running so rich what you see come out as fire is actually unburned gas from the fuel system.
Old Dec 4, 2008 | 09:56 PM
Aopocetx's Avatar
If I was running rich enough do I have any chance of shooting fire if I use a catback exhaust system? TIA.
Old Dec 4, 2008 | 10:42 PM
Aopocetx's Avatar
What are the differences between the GLT and the base 850? I'm going to a junkyard so if there's some performance parts I could pull, I will. Sway bars or anything like that?
Old Dec 4, 2008 | 11:18 PM
S70driver's Avatar
Dude he probably put a flamethrower kit on it and hit a switch.
Would you mind posting the video for us.
Old Dec 5, 2008 | 12:07 AM
TIPSP's Avatar
Got Boost?
ORIGINAL: Aopocetx
They are pretty much the same. The base is not turbo'd though.
You should be able to swap the swaybars, but I think they are the same.
Edit: Hey s70driver....haven't seen you on in awhile.
Old Dec 5, 2008 | 01:51 AM
Aopocetx's Avatar
I wish I had a video but anyway thanks for all the help in this thread! Definitely taking the sway bars - I need them!
Old Dec 7, 2008 | 01:21 PM
VJZ's Avatar
VJZ
My thinking is that this guy needs some serious help maintenance wise on his car.
Perhaps his PCV system is totally fubar'd and clogged.
Old Dec 10, 2008 | 03:44 PM
Aopocetx's Avatar
I did a stage 0 tune and put a K&N air filter and a magnaflow catback.
john12345
Sep 4, 2013 07:38 PM
S70driver
May 25, 2009 06:51 PM
tech
Aug 30, 2008 11:11 PM
ddoose
Aug 23, 2008 04:38 PM
englishmike
Mar 30, 2007 11:44 AM
