Question on 'Service' light and vent removal?
Old Apr 11, 2013 | 12:18 PM
johnwartr's Avatar
Default Question on 'Service' light and vent removal?
I am preparing to replace the failed gears in my odometer.
The instructions indicate that I need to remove the vents from my dash to access the screws to get the gauge cluster out.
How do I remove the vents? I am not familiar with the procedure.
Also, does the service light that blinks every time I start the car serve any purpose, other than to remind me that a certain number of miles have passed since the last service? I don't have the right tool to turn it off. If it only indicates that I need to check or service something, I'm considering taking the bulb out for it while I have the cluster out.
Thanks!
Old Apr 11, 2013 | 01:12 PM
ibified's Avatar
John: for the vents, i usually slide a small screwdriver in the side, and gently pry them out. Service light bulb: yes, just pull it. I did.
For removal of instrument cluster, pleasze be aware that you have to remove the entire top of the dash - that involves taking the screws that are behind the vents out, a couple screws on each side where the door closes on them, the dash speakers, the glove box, etc. I think there is a writeup on it somewhere on the forum...I'll see if i can find it for you. Set aside a couple hours for your first time doing this, and it helps to have an assistant to help you lift the dash out of place - its awkward, because it will have the passenger's side airbag atached to it.
Old Apr 11, 2013 | 01:21 PM
johnwartr's Avatar
Thanks
Instructions are linked here:
Odometer Gears - Volvo - 850 92-97
Old Apr 11, 2013 | 06:26 PM
ibified's Avatar
John:
That a good general idea, but its MUCH easier to do if you completely remove the top of the dash - from there you need to pul the glove box liner, out, unplug passengers side air bag, and remove the 4 10mm bolts that hold the airbag module to the dash supports, and also remove the screws in the door crease (as in the first step) to get the whole dash off. I've seen people try to take half the dash loose only to wind up creasing it from trying to pull the instrument cluster out.
Old Apr 11, 2013 | 08:24 PM
What year is your 850 ??
Old Apr 11, 2013 | 09:13 PM
johnwartr's Avatar
I have a 97 850R Wagon
Thanks!
Old Apr 11, 2013 | 09:49 PM
On your year you might need the dealer to do it.
Volvo 850/70 Service Light Reset
Old Apr 12, 2013 | 08:45 AM
johnwartr's Avatar
Unless there's a reason not to.. I'm gonna pull the bulb.
I can remind myself to do oil changes and maintenance
Old Apr 12, 2013 | 02:48 PM
It's best to remove the entire dash pad. They are very brittle and will break if you try to get the cluster out of it by lifting one side up.
Dash Pad Removal, Volvo 850
lalawhipper
Oct 15, 2012 11:16 PM
brunnmat
Aug 15, 2009 06:48 PM
dan2286
Mar 29, 2009 07:17 PM
mrbeavin
Apr 15, 2008 02:06 PM
spelton
Jul 23, 2006 01:17 AM
