Questions with PICS
Old Jan 7, 2010 | 06:36 PM
gorillajin's Avatar
Default Questions with PICS
Hi,
I have a few questions about my engine condition. I couldn't find haynes repair manual at a local parts store. I guess I have to order online.
Anyway, is this a upper engine mount? It has a crack and I need to replace it.
And if you look at the picture, (indicated the area with a white arrow) behind the passenger side engine, there are 2 metal pipes and there is oil leaking. What are those lines?
Thank you.
Old Jan 7, 2010 | 10:47 PM
MC92's Avatar
Yes, that is the upper engine mount and I believe that's the fuel lines?
Old Jan 8, 2010 | 07:56 AM
boxpin's Avatar
Correct, thats an upper engine mount (that is cracked and needs replacing) and those are the fuel lines. You also need a new oil cap seal.
Old Jan 8, 2010 | 11:38 AM
sauer9's Avatar
thanks for the pics - even with the haynes manual I have a hard time identifying everything.
Newbie
Old Jan 8, 2010 | 10:15 PM
mhutchens's Avatar
On the fuel lines is that oil or grease? Check your CV Joint boots, looks like one may be cracked.
Old Jan 9, 2010 | 11:19 AM
gorillajin's Avatar
Thank you for the reply.
I checked the cv boot but it looked fine. I see a bit of wetness below crank pulley, so it might be front cam seal. It is not bad at all, no dripping oil or anything like that. It's just wet there. After I replace all the pcv system, I will check one more time.
Old Jan 9, 2010 | 11:21 AM
Clean it all up good and drive it some and recheck it.
Phil 850
Jul 25, 2012 10:01 PM
mcaanda
Sep 21, 2010 07:53 PM
BlackDiamondBound
Jul 7, 2005 10:44 PM
SuperCoupe93
May 1, 2005 06:32 PM
