QUICK QUESTION!!!
Old Feb 15, 2007 | 01:18 PM
hockeymatt2727's Avatar
Default QUICK QUESTION!!!
hows everyone doin? anyways its freeeezing over here in MA and i have a question about my heater.
at first id put the heat on and it worked fine. but when i would shut the car off, the heater would make a low whining sound then shut off with the rest of the car.....i didnt think anythin of it, BUT
now, when i have the heat on high it makes alot of noise. especially when i first start the car up. it howls a little, and makes whining sounds. it does this most of the time now.
i know i need a new thermostat for the car, but i dont think that has anythin to do with it. im thinkin i need a new heater motor?? and if so where would be the cheapest and best quality to purchase one?
thanks,
matt
Old Feb 15, 2007 | 01:42 PM
B1mmer's Avatar
Default RE: QUICK QUESTION!!!
You'll need a blower motor. FCP Groton, Eeuroparts.com and others all sell them. You can buy it with or without a cage. I bought mine with because I didn't want to swap over the cage. It cost me around $140 and took about 40 minutes to swap out. It's located behind the glove box. - AB
Old Feb 15, 2007 | 02:06 PM
JimKW's Avatar
My son just put one in his 98 V70 R and he got it at the dealer for around $200. FCP Groton would have been around $180 and he would of had to wait for delivery. The Volvo dealer here gives me a 15% discount. The list on the motor and cage was $225.
Old Feb 16, 2007 | 02:28 AM
JPN's Avatar
JPN
Hello Matt,
Greetings from frozen Chicagoland.
I have a friend in Fall River MA, BTW.
FCP Groton has two different brand blowersnow (they used to have only Behr, A German unit):
http://www.fcpgroton.com/volvo850cooling.htm
Once the blower starts to make noise, you pretty much have to replace it, as the two gentlemen above have stated. I tried to clean it, lubricate it & re-install it but the problem disappeared only for 2 days. I bought Behr blower from FCP Groton afterwardand it seems to be of high quality.
I would buy a blower with cage attached to it, this makes the replacement easier.
Good luck,
JPN
Old Feb 16, 2007 | 04:02 PM
B1mmer's Avatar
To follow up on JPN's post, change out the motor soon. If it seizes, you will also need to buy the ACC resistor as well, which is about $80. Ask me how I know [:@]- AB
colgate41
Oct 12, 2006 09:41 PM
tomservo
May 16, 2005 12:36 AM
eurochick
May 10, 2005 01:27 AM
jaz
May 7, 2005 12:59 AM
volvobacon
Apr 17, 2005 01:24 AM
