Quick Radiator Fan Question
Old Jun 17, 2016 | 12:19 AM
Luke Woessner's Avatar
Question Quick Radiator Fan Question
When you turn on the A/C compressor, does the radiator fan kick on automatically? To test the radiator fan which plug from to relay do you connect directly to a 12V source? Left, right or middle? What number goes to what battery terminal? (+ or -) Read this on another form post and wanted some clarification.
https://volvoforums.com/forum/volvo-...n-relay-14822/
Old Jun 17, 2016 | 07:30 PM
tryingbe's Avatar
Yes, radiator fan should turn on when a/c is on.
No, you do not connect a 12v to the relay to test the fan. That is a two speed fan relay, you connect to either 2 - in or 1 - in to a ground, that would turn the fan on high speed or low speed.
30 is the 12v source , 2 - out and 1 - out both goes to the fan for high or slow speed.
I'm not sure which wire is which speed.
If you want to bypass the relay, undo the red/green plug, get a thick 10 gauge wire and use it to connect from a 12 v source to either red/green wire that connects to the fan.
Old Jun 17, 2016 | 09:14 PM
The radiator fan does not kick on when the A/C Compressor is on. The A/C still blows cold consistently. Would that point to a bad relay? Step by step directions to manually test the fan? (Tools available, continuity tester, basic multimeter, gator clams & wires)
Old Jun 17, 2016 | 10:21 PM
tryingbe's Avatar
Testing procedure already given, those two test the relay and fan motor.
Old Jun 17, 2016 | 10:42 PM
Engine Cooling Fan Control Switch Relay Module for Volvo C70 S70 V70 S90 V90 | eBay
https://www.rockauto.com/en/moreinfo...851&cc=1433981
In case it is just the relay, these would both be valid replacements, correct? 2.4L Base sedan (I have only a very rough understanding of what I'm doing)
Old Jun 18, 2016 | 07:50 AM
tryingbe's Avatar
Yes, relay is on top of the radiator.
Old Jun 18, 2016 | 10:30 AM
When I was replacing the coolant and thermostat, I noticed a second relay under the splash guard on the drivers side in front of the right wheel, near the radiator petcock. It was also labeled as a fan relay. Any input as to the purpose of this? A/C relay or something different?
Old Jun 18, 2016 | 01:25 PM
tryingbe's Avatar
Doesn't sounds like a factory setup, but then it would help to know what we're working on here since a 1996 C30 does not exist.
Old Jun 19, 2016 | 01:43 AM
1996 850 Base model Sedan (wouldn't let me set it to anything else and the garage bugs out on me)
Old Jun 19, 2016 | 06:30 AM
tryingbe's Avatar
Pictures would help. Have you tested the relay in your links yet?
Old Jun 19, 2016 | 12:04 PM
Fixed the garage post (had to delete and re-upload) I'm awaiting delivery for a multimeter to make testing the relay easier & more accurate.
ingydrummer
Feb 28, 2020 03:33 PM
gabanja05
Jun 15, 2011 12:12 AM
rjb44
Feb 14, 2011 12:21 PM
elouadj
Jun 25, 2008 07:00 PM
laroqet
Engine & Internal
Jan 6, 2007 12:01 PM
