R213FAQ: VIN Engine and Turbo Codes
Old Aug 20, 2005 | 04:41 PM
robert213's Avatar
Default R213FAQ: VIN Engine and Turbo Codes
Work-in-progress... To be completed later...
41 - B5202S
45 - B5204S
47 - B5204T
51 - B5252S
53 - B5234T3
54 - B5234S
55 - B5254S
56 - B5254T - TD04-13G
57 - B5234T - TD04-15G
58 - B5234T5
http://volvospeed.com/vs_forum/index...howtopic=29043
ORIGINAL: anitanium]
quote=anitanium,Aug 13 2005, 11:04 PM
Engines and turbochargers
12T - B4204T 160hk 1998-1999, S/V/40 twin scroll
12T - B4204T5 165hk 2000-, S/V/40 twin scroll
12T - B5204T3 225hk ??-?? C70
12T - B5204T4 163hk ??-?? C70
12T _ B5204T5 180hk ??-?? S60
14T - B4194T 200hk 1998-1999 S/V/40
14T - B4204T3 200hk 2000- S/V/40 twin scroll
14T - B5254T2 200hk ??-?? S60/V70
13G - B5254T 193hk 1996-1998, straight outlet from turbine
13G - B5244T 193hk 1999-2000, angled outlet from turbine
13G - B5244T 200hk 2001, angled outlet from turbine
15G - B5234T 225hk/B5234T5 240hk 1994-1995, The old conic outlet
15G - B5234T 225hk/B5234T5 240hk 1996, straight outlet form turbine.
16T - B5234T4 250hp kom 1996 i 850R man, straight outlet from turbine
16T - B5234T3 240hp 1997-1998 finns i S/V/C70 T5, straight oulet from turbine.
16T - B5234T3 240hp 1999-2000 finns i S/V/C70 T5, angled outlet from turbine.
16T - B5234T3 250hp 2001- alla S60/V70N T5, angled outlet from turbine.
18T - B5234T4 250hp 1997-1998 only S/V70R man FWD/AWD, 275/60 wastegate and straight outletform turbine.
18T - B5234RT 250hp 1999 only V70R AWD, 4-vxl aut, 300/70 wastegate and angled outlet form turbine.
19T - B5244RT 265hp 2000 endast V70R AWD, 5-vxl aut, 300/70 wastegate and angled outlet form turbine.
Old Sep 7, 2018 | 08:09 AM
benzene's Avatar
Hi can anyone there confirm B4204T5 motor power output and model of turbo charger which bolted on it.How they manage to produce 147 kw if I am right b4204t2 only pump out 118kw .is high pressure and low pressure turbo that makes this big different.or just the engine management .The list above says power output 165hk, for t5 that contradicts on some websites.Thanks Edith My engine code is 37 on VIN.
Old Sep 9, 2018 | 11:43 AM
You can check out the Wiki for Volvo modular engines to see specs by build code. B4204T5 points to the S40 T4 (only the 1.9T came to the US) which used the 14T sized TD04. The 1.9T with the 160 HP output uses a 12T turbo and less boost (ie LPT design vs HPT design.)
here's what it says:
B4204T5[edit]
The B4204T5 is a 1.9 L (1,948 cc) straight-four.[70] Bore is 83 mm (3.3 in) and stroke is 90 mm (3.5 in). It is turbocharged and intercooled with a power output of 197 hp (147 kW; 200 PS) at 5500 rpm with 300 N⋅m (220 lb⋅ft) of torque at 2500–4000 rpm.
Applications:[71]
OGC70
Sep 29, 2014 09:22 AM
brents
Jul 20, 2014 05:57 PM
8blade6
Jul 17, 2009 05:35 AM
jasonbrown58
Dec 12, 2007 07:14 PM
ryankayla13
Sep 11, 2007 03:37 PM
