radio code
Old Jul 19, 2010 | 10:18 PM
97850glt's Avatar
Default radio code
I had a dead battery today ,so now the radio displays"code" when it is turned on,how do I find the code,and what does the dealer charge if thats where I need to go next?
Old Jul 19, 2010 | 10:23 PM
mudpie's Avatar
Go to the dealer, they'll come out and pull the radio, write down some numbers off the tag on the top, and look it up for you. It should take just a couple minutes, and they won't (shouldn't) charge you anything.
Old Jul 19, 2010 | 11:08 PM
vpatrol's Avatar
does anyone else have a generic code on theirs? Mine was 666666. (I'm in NZ so I feel safe nobody will pinch my radio)
Old Jul 19, 2010 | 11:14 PM
mudpie's Avatar
The last 4 radios I've had checked have all been some combination of the numbers 1,2,4, and 6. Like 6421, 6142, 4261, etc. Probably just an odd coincidence.
Old Jul 20, 2010 | 09:35 PM
douglas swearer's Avatar
it is part of vin number backwords near the end 4 #s. go to the veh/vin number try putting in your 4th number from the end and the 5th from end then 6th from the end and your last code number would be the 7th number from the last number if your number is BF2S8928739234561 - you would use 4329.
Old Jul 25, 2010 | 10:58 AM
air force rascal's Avatar
You also may want to check the label on the outside of the Radio..sometimes people will right the code there in case they forget it...not a very good place to put it..but it works. It should be a 4 digit number. If not on the label..somewhere on the radio with a magic marker. Good Luck and Happy Motoring !!!
Old Jul 25, 2010 | 10:44 PM
mudpie's Avatar
Originally Posted by douglas swearer
it is part of vin
Volvo had lots of problems with the radios, and many of them were replaced. As such, I would guess very few have a code that is related to the VIN anymore.
In all the cars for which I had the original owner manual, the dealer had written the code in the section that shows the operational controls for the radio. If you have your manual, you might look there too.
Old Jul 26, 2010 | 07:03 AM
JimKW's Avatar
Some dealers will give you the code if you all them with your vin. That's assuming, of course, it's the original radio for that car. If not, you can get it from the serial number off the head unit. Again you need to give that number to the dealer.
I am going to check mine tonight to see if it's really part of the vin. I have never heard that before.
Old Jul 26, 2010 | 07:34 AM
97850glt's Avatar
I got lucky when I pulled the radio someone had wriiten the code on the top lable,pushed it back in and entered the code and it fired right up.Thanks for all the help
Old Jul 26, 2010 | 10:54 AM
boxpin's Avatar
I see you got it going...excellent.
Here is some pointers for future readers.....
The code is not part of the VIN. The code is in a database based on your VIN. Some radios have been replaced and using the VIN will no longer work. But, the radio has a serial number on it and it can be traced that way too.
Either way, the dealer has your code. If they are nice, you get it for free. If not, you pay. The best thing to do is simply call them and tell them you replaced your battery and now your radio is saying CODE. It is so easy for them to get your code they will probably want to simply help you for customer service points. Just have your VIN -and- radio serial number ready for when they ask for it.
As stated, some people have their code written on the radio...I do. If it gets stolen what do you care if you have the code written on it or not...its gone. Some people write it in their owners manual and there is actually a card that might be in your documentation that has the code on it. Search first, then get your VIN and Serial then call the dealership.
Old Jul 26, 2010 | 06:29 PM
JimKW's Avatar
I just check my codes against my vin and there is no correlation whatsoever.
Old Jul 26, 2010 | 09:00 PM
97850glt's Avatar
yes,there is not with mine either
cbgav
Sep 10, 2007 05:25 PM
jayb
Aug 27, 2004 09:29 PM
Cyrusjj
Nov 15, 2003 06:33 PM
