Rattel on the front end
Old Aug 6, 2012 | 01:24 AM
ded137t5r's Avatar
Default Rattel on the front end
I assume it is the passenger dust shield being loose that is making all the rattles. So I took the wheel off and i cant see anything loose. where is the bolt or where is it attached of fastened? how can I tighten it back up?
Old Aug 6, 2012 | 07:25 AM
VTBricked's Avatar
Dust shield are attached with bolts. You need to remove the brake disk to access them. But I don't think you will find they are loose.
Old Aug 6, 2012 | 12:32 PM
ded137t5r's Avatar
ok well then why would It be loose and cause all the rattle? do they tear or rip causing them to be loose?
Wing0
Dec 13, 2013 02:39 PM
Bruno937
Mar 8, 2009 12:41 PM
The.method
Jan 19, 2009 08:06 AM
alireza1344
Oct 19, 2007 08:33 PM
