Rear Caliper Mounting bolt size problem!!!!
Old Mar 28, 2011 | 07:04 PM
jamesdubbeld's Avatar
Default Rear Caliper Mounting bolt size problem!!!!
Hey guys,
I'm doing my brakes and when replacing my rear calipers I was told there are two sizes- in regards to the mounting bolts. Either 10mm or 11mm holes. How do I figure that out without taking them off?
I have a 1997 Volvo GLE.
Any help would be apprecaited!!!
Thanks
Old Mar 28, 2011 | 07:45 PM
MattyXXL's Avatar
Yes they do for a 97 850... 10mm and 11mm
I would pull a wheel and a bolt and measure the bolt to be sure... it should only take 3 min to figure it out...
If you dont have a caliper to measure..
10mm is a Little over 3/8 Inch... or 0.39370 Inches
11mm is 7/16 Inch... or 0.43307 Inches
Old Mar 28, 2011 | 09:28 PM
ibified's Avatar
either measure the bolts or take the wheel off and attempt to put a 10 mm wrench on the bolt and see if it fits. if it does, its a 10 mm, if it doesnt, its an 11 mm.
Old Mar 28, 2011 | 10:08 PM
MattyXXL's Avatar
thats slick.... I never would have had the common sense to think of that..
See you DO learn something new everyday...
Old Mar 29, 2011 | 12:58 PM
boxpin's Avatar
This would be one of those things you never admit.
Old Mar 29, 2011 | 01:14 PM
ibified's Avatar
thats kinda what I was thinking. I was like "am i missing something here?"
Old Mar 29, 2011 | 02:51 PM
MattyXXL's Avatar
LMAO..I could admit when I had a brain-fart.. but I would have used a digital caliper to measure and not even thought of the wrenches... WOW, im gunna shut up now
Baldmccartney
Jul 19, 2015 07:07 PM
calvinhoe
Mar 28, 2011 11:49 AM
zloetakoe
Mar 21, 2011 04:22 PM
AnEskimo
Jun 9, 2010 10:45 AM
JimKW
Mar 19, 2007 03:26 AM
