Rear cam seal question
Old Sep 3, 2011 | 09:34 PM
ga11sport's Avatar
Default Rear cam seal question
I am dealing with a slow oil leak near the intakes rear cam seal on a ‘96 850R, my issue is when I pulled the seal I found a rough cut hole in the lower cam cover behind the seal. Can someone verify for me that the hole is suppose to be there? Is it an oil drain hole?
I would just assume it is suppose to be there but it is such a rough opening, like someone stabbed it with a screwdriver while trying to get a seal out. That and I have oil leaking from what appeared to be a good condition seal. Thanks for any verification.
Old Sep 4, 2011 | 02:09 AM
ibified's Avatar
shouldnt be there...time to find a new head.
Old Sep 4, 2011 | 08:12 AM
Are you talking about the cam seal under the cam shaft sensor? Near the upper torque mount? I have a few pictures of those areas on my cam seal replacement instructions in the DIY sticky.
Old Sep 4, 2011 | 02:57 PM
ga11sport's Avatar
I did not find the cam seal replacement instructions you spoke of. I just read through the whole cylinder head replacement tutorial though, very informative but the only pictures for the seals had them installed already.
I am actually talking about the camshaft end seal behind the distributor. I pulled out the seal and found the hole behind it. “ibified” seems to think it should NOT be there, can anyone second that before I figure out my next step?
Old Sep 4, 2011 | 03:37 PM
That is the rear intake cam shaft seal. Here are my instructions, maybe the last pic at step 19 will work.
Cam Seal Replacement, rear, 1998 Volvo S70 GLT - Volvo 850 Cam Seal Replacement
If not, let me know and I'll e-mail you some more pics.
Old Sep 4, 2011 | 03:46 PM
I just looked through my photos and I noticed a good size hole in my front intake cam shaft area. If it's behind the seal, it should NOT be a problem. Just put a new seal in there and it will keep the oil behind it.
That area seems to be a slosh area, no real pressure behind there unless you have a plugged PCV system.
Old Sep 4, 2011 | 04:11 PM
ga11sport's Avatar
So the hole/crack along the very bottom in this picture, if my picture worked, is suppose to be there then? Guess it makes sense behind the seal, that is what a seal is for right. It just looks like they took a flat screwdriver and gave it a whack to make the hole though.
Old Sep 4, 2011 | 08:09 PM
That actually looks like the cam is damaged. I thought it was a hole on the head. That may cause the cam to vibrate or wobble in the head and cause you more problems down the road. I would start looking for a cam or set of cams if I were you. You may have time but I would be a little agressive with it. Others may have a different suggestion for you.
Old Sep 5, 2011 | 02:33 AM
ibified's Avatar
Sorry, I misunderstood and thought you meant that the chunk was out of the head. Now that I see what you are saying, I agree with rspi.
And if you're gonna get new cams, get cams from an N/A. You'll REALLY like what that does for the car if you time them right.
akem21
Mar 11, 2013 01:12 AM
thing1
Jan 4, 2012 03:48 PM
MattyXXL
Jul 14, 2011 11:40 PM
Dsssurf
Jul 1, 2010 12:04 PM
WalterXI
Apr 9, 2010 01:36 PM
