Rear suspension problems
Old Apr 26, 2018 | 08:39 PM
Travis85904's Avatar
Default Rear suspension problems
i just bought a 94 850 turbo from auction. I had to drive it home due to the rear tire being blown out. The rear passenger side tire actually sits inward a bit and that is how the tire blew out. I’m wondering if someone may have an idea as to what component(s) could be causing this issue and if it is repairable.
https://imageshack.us/i/pmtBpUalj
https://imageshack.us/i/poPvpNchj
https://imageshack.us/i/pnpdR5lJj
https://imageshack.us/i/po7p274ij
https://imageshack.us/i/pmmbp7ryj
Old Apr 26, 2018 | 08:44 PM
Check the rear delta link bushings - for the bushing directly in front of the tire, make sure the bolt to the chassis isn't rusted out.
Old Apr 26, 2018 | 10:03 PM
firebirdparts's Avatar
That doesn't look good. When you get under there, it's mostly obvious where everything should be. The axle is in two pieces which are anchored to each other. Each piece has a trailing arm built into it near the wheel, and that's where this bushing is. The junkyards are full of them, so if you decide it's bent real bad, just find a whole axle at the pull-a-part. Just 4 bolts hold it in, and two of those are on the end of the shocks.
Old Apr 26, 2018 | 10:58 PM
So basically if I replace the rear axle that should take care of my problem?
Update:
here is a pic of the rear axle. Looks bent to me but I’m not sure if it’s supposed to look like that
Old Apr 27, 2018 | 07:09 PM
tryingbe's Avatar
It looks bent.
Old Apr 28, 2018 | 08:45 AM
That is not supposed to look like that. You could replace half the axle, but I think the whole axle will be a lot easier. Like I said, 4 bolts and it just falls off. Disentangling the brakes will be more trouble that the actual axle.
rietherll
May 14, 2012 06:46 PM
spioana007
Mar 22, 2010 12:12 AM
knots
Mar 6, 2009 10:23 AM
knots
Mar 8, 2008 02:46 PM
volvo4lifeson
Mar 5, 2007 06:08 PM
