relay location
Old Jun 8, 2006 | 07:58 PM
typercivic92's Avatar
Default relay location
where is the a/c relay located at on a 94 850. my air stoped working the other day. i jumped the low pressure switch out still nothing. the fuze is still good. but the compresser is not coming on or the blower motor. please help me
Old Jun 8, 2006 | 08:58 PM
Default RE: relay location
So I have this right the blower and the compressor doesn't come on?
The relay only controls the compressor.
The blower is on a different circuit.
Might be a bad A/C module.
Old Jun 10, 2006 | 06:48 PM
ok the blower is working but the compresser is still not kicking in.
Old Jun 10, 2006 | 09:08 PM
Do you have power to the low pressure switch?
Old Jun 11, 2006 | 03:29 PM
robert213's Avatar
Start trouble-shooting your AC compressor problem right here...
https://volvoforums.com/m_30486/tm.htm
Old Jun 11, 2006 | 05:58 PM
no power at the pressure switch
Old Jun 11, 2006 | 10:10 PM
Do you have ECC or MCC?
Old Jun 13, 2006 | 02:21 PM
how would i tell if it was manual or Electronic?
Old Jun 13, 2006 | 07:52 PM
Ecc is electronic climate control. The temp dial has Numbers on it. Also it will have AUT on the temp, and fan switch.
Old Jun 15, 2006 | 07:14 PM
ok then it is mcc. i really need to know where this relay is please
Old Jun 15, 2006 | 07:54 PM
It will be in either of the 2 places. The Main relay box under the hood or you will have to remove the fuse box cover and look under there.
Here is a link for a site that has a wiring diagram you can look at to help you back track from the low pressure switch and find the problem.
http://www.volvotechinfo.com/WD123/
Old Jun 20, 2006 | 08:51 PM
ok it was not the relay. i changed both of them. the compresser is still not coming on. if i jump the comp to the batt. the clutch will ingauge. what elsa to look at?
and it has mcc
Old Jun 20, 2006 | 08:52 PM
and i have like 8.7v at the pressure switch
Old Jun 21, 2006 | 12:30 AM
Do you have any codes in the engine control module?
Old Jun 21, 2006 | 05:49 PM
no i dont have any codes in the ecm
Old Jun 21, 2006 | 09:01 PM
  #17
HMMM check and follow the wiring diagram.
It is hard to tell you much more without seeing the car.
I have run out of Ideas.
All that I have posted comes from all that I have seen wrong.
sleech
Jan 25, 2020 05:07 PM
dads 740 turbo
Oct 24, 2008 06:54 PM
pvolvoman
Feb 17, 2007 12:44 AM
madhatter
Dec 7, 2005 06:00 PM
steves96
Nov 14, 2004 11:40 PM
