Remote Doorlocks
Old Jul 3, 2008 | 02:03 PM
raybun's Avatar
Default Remote Doorlocks
How do I determine if my 1996 850 has been fitted with the reciever for remote door locks? Dealer epair slips from back when the car was new refer to it as a model 55.
Thanks
Ray
Old Jul 3, 2008 | 02:41 PM
jks2's Avatar
Default RE: Remote Doorlocks
Is there a lock button on the dash to the left of the steering wheel? If so then it probably has the ability to be locked with a remote.
Old Jul 3, 2008 | 06:54 PM
I think all of the 850's came with keyless entry.
Old Jul 4, 2008 | 01:59 AM
Quick Brick's Avatar
Hey gang,
I have a 1994 850 but I don't seem to have the lock button to the left of my wheel. The dash it fairly clear but maybe I just have not noticed .
Ido have the central locking system and two fobs but think that I need to replace them, rubber pads have worn pretty good,as there are times that they will work and others not. Always seems to unlock the car but when it comes to locking, that can be hit or miss at times. And yes I have changed the batteries [sm=smiley36.gif].
I am, almost, positive that someone else here has added the unit that controls the locks but I can not find the post. It seemed to work for him.
I will look again as there were a lot of posts going back and forth on that one.
[sm=icon_cheers.gif]
Old Jul 4, 2008 | 07:58 AM
Ozark Lee's Avatar
My son's car came with electric locks but no remote and no alarm. I picked up a remote receiver and the remotes off of eBay and it was plug and play after we programmed the remotes.
The only way to tell for sure is to remove the glove box and look over toward the A pillar for a black box with a green connector plugged into it that that says ALPS Electronics on it. While there, note the model number and the FCC identifier number which is in the fine print so that you can buy the appropriate keyfobs.
...Lee
Old Jul 5, 2008 | 01:38 AM
Psaboic's Avatar
Good tip!!
schmuecker
May 19, 2011 06:45 PM
pardus
Feb 11, 2010 11:57 AM
digimower
Aug 17, 2008 12:55 PM
sudvam
Oct 30, 2003 12:56 AM
