Remote Entry Problem
Old Feb 12, 2007 | 10:33 PM
rosamila's Avatar
Default Remote Entry Problem
Hi!
My remote entry has gone dead - [:@]. Central locking works with the key. Changed the battery on the remote key fob, checked all the obvious fuses, tried the 5 on/off thingy with the doors locked and a cold bottle of bud. I did notice that the RED led on the dash doesn't light anymore. Any thoughts on what the problem is?
TIA,
Rosa (newbie)
Old Feb 13, 2007 | 12:18 AM
Default RE: Remote Entry Problem
Did you check and see if there is a fuse for the system?
The relay might have gone bad.
Not sure of to much about the system. Most people never want to spend the $$$ to get it fixed.
Old Feb 13, 2007 | 10:33 AM
rosamila's Avatar
Had a look at the relevant fuses in the fuse box in the engine compartment and they all check out fine. Is there another fuse somewhere? Where would the relay be located for the system?
Thanks!
Old Feb 13, 2007 | 01:45 PM
billofdurham's Avatar
The red LED is connected to the alarm system to show it has been activated.
You haven't said the year of your car so I have taken one from the middle:
The alarm relay is #14 on the central electric unit.
Central locking relay is #11 on the CEU.
Fuse #2 covers the alarm system.
Fuse #6 the central lock and alarm.
Fuse #32 the remote central locking system.
On other year cars there may be a slight difference in the position of the fuses.
Old Feb 17, 2007 | 12:59 AM
The relay is under the dash in the box like right under where the fuse box is under the hood.
The fuse box actually goes through the firewall into the car.
Gonzspeed
Oct 16, 2007 07:23 AM
montanavolvo
Dec 14, 2006 12:39 PM
bwaymire
Feb 22, 2006 12:49 PM
JC
Nov 6, 2005 09:27 PM
dmoney
Jul 21, 2005 10:22 PM
