Remove rear shelf carpet on 850
Old Aug 19, 2016 | 01:42 PM
johnwartr's Avatar
Default Remove rear shelf carpet on 850
I am working on an 850 sedan that has a broken seat belt.
I got one from a car with a mechanical failure at the salvage yard. Figured getting one from a wrecked car was a bad idea
But, I can't figure out how to get to the top mounting bolt. On the salvage yard car, the back window was busted out, and I just ripped the carpet padding around it.
On my car, I'd prefer to keep the carpet intact. But I'm not sure how to remove it.
I'm also pondering a complete interior swap, and would like to know how to get the carpet off the shelf in the 'donor' car in one piece, so I can reuse it.
Who has some words of wisdom?
Thanks!
Old Aug 25, 2016 | 08:56 AM
rcsoundn1's Avatar
In my expirence with other cars, not this one specifice, THe rear upper seat had to be removed to take the rear shelf out. Take a look between where the upper and lower seat cushions meet, check for bolts that hold the lower &/or upper section in. You may have to remove both seat parts to do it correctly.
Old Aug 26, 2016 | 07:22 AM
firebirdparts's Avatar
It's got a fold down seat.
Old Aug 26, 2016 | 08:05 AM
johnwartr's Avatar
Update:
To remove the carpet, you must remove the 8 8mm nuts that hold the 2 speakers down, as well as unhook 2 plastic clips that are visible after you fold the back seat backs down flat. Then, lift.
greenman86
Feb 18, 2016 07:18 AM
orangekid
Aug 21, 2015 11:59 AM
alecw81
May 7, 2010 10:54 AM
GaryBrad
Dec 21, 2005 04:22 PM
floryed
May 3, 2005 09:55 PM
