Removing Center Console
Old Sep 23, 2006 | 10:43 PM
MikeySq's Avatar
Default Removing Center Console
ORIGINAL: tech
First start off by removing the center console.If it is a 850 remove the front cubby by reoving the 2 T-25 screws then under the cover is 2 T-15 screws remove them.Unplug the black and grey plugs in the hole by the 2 T-15 screws.Then lift up the armrest and remove the black cover and remove the 2 8mm or 10mm screws.The early 850's may have T-25 screws
I've been having problems with removing this part, I have the console loose i removed the screws inside and under the cover and i have it loose, but for some reason I can not remove the unit from under where the ash tray is, any one know why this is being a pain to me and why it will not come from under the front part? Does the dash area arounfd the ash trah and stereo have to come off?
thank
-Mike
Old Sep 23, 2006 | 11:32 PM
Default RE: Removing Center Console
Soemtimes it is tricky and you have to pull and wiggle it to get it to come loose.
Don't be afraid to tug on it.
Argievolvo
Feb 16, 2017 09:56 AM
I8ASaleen
Jan 3, 2017 09:01 AM
shelby187
Jan 8, 2012 03:59 AM
ReyM463839
Dec 4, 2010 05:01 PM
socko
Aug 27, 2009 09:02 PM
