Replacing Expansion Tank
Old Jul 15, 2010 | 01:53 PM
thebosses's Avatar
Default Replacing Expansion Tank
I have diagnosed my problem and should be receiving my new expansion tank and hose today, thanks for the help.
I read through a number of other threads and understand that this is a pretty simple swap and shouldn't have any problems. I saw in another thread that the cap should be replaced as well. Is this necessary? Is there an easy way to check my existing cap?
Old Jul 15, 2010 | 04:18 PM
vjaneczko's Avatar
I'd replace the tank and see if there's any overheating problems before you swap the cap.
If you do replace it, do some research first; I read something awhile back that talked about a gray cap and a green cap. Seems they have different ratings and some people got one when they should have gotten the other - I just can't keep it straight in my head...
Old Jul 15, 2010 | 05:04 PM
MC92's Avatar
Green cap is the better one from what I've heard. There was a talk saying the gray one didn't hold the pressure or something that well.
Old Jul 16, 2010 | 07:57 AM
fcpgroton's Avatar
Former Sponsor
That is correct. If you are going to end up needing the cap, order one of the green ones.
Old Jul 16, 2010 | 02:29 PM
thebosses's Avatar
Done and done. Thanks for the tip. It looks like my cap is ok. I broke the blue wire on the darn sensor while I was changing the tank but was able to get a new on locally.
curtisckey
Sep 22, 2019 12:26 AM
jlhoward06
Feb 5, 2008 11:17 PM
AlX
Nov 19, 2007 03:23 AM
nebsch
Oct 9, 2007 09:03 PM
snulma1
Dec 28, 2006 11:19 AM
