Replacing Inner Tie rod ends
Old Jun 21, 2011 | 11:13 PM
91shelby's Avatar
Default Replacing Inner Tie rod ends
Well im going to finally replace my inner tie-rod ends, but do i need to rent the tool kit or can i do it without it?
Old Jun 23, 2011 | 10:47 AM
TonyS's Avatar
Nice tutorial here:
http://www.v70xc.com/resources/how-t...r-tie-rods.pdf
Old Jun 23, 2011 | 12:53 PM
91shelby's Avatar
thanks
Old Jun 24, 2011 | 09:35 AM
Rickford's Avatar
That's an exl write up. It looks like that's about same process on a 850NA. Is that correct or is there some major difference I don't know about? Never done front end work but looks doable. Can I refer to this for my 850? Thanks!
Old Jun 28, 2011 | 01:02 PM
TonyS's Avatar
I'm in the middle of using it to do the inner and outer tie rods on my 1996 NA 850 wagon and it seems right on. I'm trying to save the bellows, rather than cutting them off as recommended in the tutorial. The bellows I ordered from FCP Groton seem quite a bit shorter and flimsier than the originals. Looks like you can push them down toward the inner tie rod and still get a wrench on that collar.
Old Jun 28, 2011 | 11:05 PM
91shelby's Avatar
i replaced them within 2 hrs. how ever my wagon still wants to wander just not as bad now, what else could it be? there is no in and out play on the rack but very very slight front to back losness
Old Jun 29, 2011 | 01:04 AM
trs80's Avatar
Have you checked the control arm bushings?
Old Jul 30, 2011 | 01:16 AM
There is a tool for doing the inner tie rod ends and most of the parts stores will loan it to you even if you didn't buy the parts there. You buy it to take it out of the store and you get a full refund if you bring it back in a day or two.
The write up is excellent!
jands
Aug 28, 2015 11:21 AM
austinbrady
Aug 19, 2011 06:06 PM
91shelby
May 29, 2011 03:24 PM
dipfrog
Jun 21, 2009 09:30 AM
fixitpimp
Apr 20, 2009 05:55 PM
