Replacing Odometer
Old Oct 27, 2005 | 03:46 PM
brianjwagoner's Avatar
Default Replacing Odometer
I looked at replacing my odometer at the dealership and it looks to be about 450, including resetting to the current shown mileage. Is this in line? Can the gear that controls the motor be fixed?
I saw someone post something about the carfax report on a vehicle, if the odometer goes out, how would it show up on the carfax. Does the dealer have to report?
Thanks!
Old Oct 27, 2005 | 05:11 PM
rp850's Avatar
Default RE: Replacing Odometer
Usually when the odometer fails it's because of a gear. Here's a site that sells replacement gears you can install yourself if you are interested.
http://www.odometergears.com/subpages/volvo.html
Old Oct 27, 2005 | 11:44 PM
Thanks! I would like to see if I can do it. I have read some of the things on the dash can be pretty intricute... anything to be overly cautious of?
Old Oct 28, 2005 | 03:04 AM
rp850's Avatar
I've never done it myself. Basically one side of the dash will have to be opened up and the cluster removed. Then you take apart the cluster to get to that gear that's broken. I'd change all the instrument bulbs while it's out. I don't think it's incredibly complicated, but it's tedious. If you go slow and use some finesse I think it's doable...
Old Oct 28, 2005 | 09:21 PM
When you do it just be careful pulling up on the dash. Some tend to break a little peice off where the pad mounts into the black part of the dash.
UA
Apr 19, 2005 06:17 PM
88_240_DL
Mar 26, 2005 03:14 PM
rperks
Oct 5, 2004 10:29 PM
j410b
Sep 8, 2004 12:01 AM
Nick Kent
Aug 2, 2004 12:14 AM
