right front axle removal 1995 t 850
Old Sep 21, 2011 | 11:22 AM
duane.mavity@yahoo.com's Avatar
Default right front axle removal 1995 t 850
does the long cross shaft to the tranny just pull out or is there some kind of keeper clip or something?????
Old Sep 22, 2011 | 12:37 PM
ibanez958's Avatar
there to 12mm bolt holding the bearing on the engine block
Old Oct 5, 2011 | 11:10 PM
Once the two bolts for that support are removed the axle should come out of the transmission but usually you need to use a screwdriver or pry bar to kind of pop it out. It's best to use two. You are prying against the aluminum case of the transmission so you want to be gentle. It's tight in there but if you can get the tools as close as possible to opposite each other the axle should pop pretty easy.
Handysmurf
Aug 4, 2013 11:35 AM
daves6987
Mar 24, 2011 09:32 AM
Soundbyte
Nov 8, 2010 07:05 AM
dbarstow
Aug 1, 2010 02:06 PM
