Riimmmmssss!!
Old Apr 29, 2010 | 12:20 PM
fattyearlman's Avatar
Default Riimmmmssss!!
will any 5 lug rims fit on a volvo 850?
Old Apr 29, 2010 | 03:32 PM
boxpin's Avatar
5x108 is what you are looking for. Someone will provide the off set, I dont know what it is. 15, 16, 17 and 18" rims.
Old Apr 29, 2010 | 07:58 PM
jks2's Avatar
If you have a 94 850 I think they were 4 lug rims. The 95-97 850's had 5 x108 bolt patterns. Offsets in the 38-43 range should be fine. 15"-17" rims will be fine. You may get some rub with the 18" ones. Tire size is somewhat dependent on what size rim you go with. www.tirerack.com shows different rims on the 850 and will give you the recommended tire size.
Old Apr 29, 2010 | 08:28 PM
TIPSP's Avatar
Got Boost?
they also sell adapters so you can mount different bolt patterns to your 5x108..
Old Apr 29, 2010 | 08:48 PM
gilber33's Avatar
93s were four lug. 94s were 5. I have Tethys on my car.
Old Apr 30, 2010 | 02:09 PM
jks2's Avatar
Thanks for the correction.
Old Apr 30, 2010 | 08:23 PM
i went on to www.discounttiredirect.com and searched my model and make and year and all of the rims that they said fit the car, were 5x100
Old Apr 30, 2010 | 08:56 PM
boxpin's Avatar
I am running 5x108s...you may want to double check before you buy.
Old Apr 30, 2010 | 09:09 PM
gilber33's Avatar
It would help if you told us what your make/model/year was
