Roof scoop ram air intake
Old May 14, 2013 | 08:55 PM
dougherty93's Avatar
Default Roof scoop ram air intake
Hello,
I have a 1993 volvo 850 and I have this idea I've come up with for a ram air intake that is fed through a roof scoop. The pipe would run from the scoop straight down into an air box and straight through the cabin and into the engine.
I have a two part question now if this is done right will it essentally work ? Or do I need to be instatutionalized? And if it will work how exactly would be the best way to do it ? I have a rough idea of how I would do it with PVC.
Thank you all !
Old May 14, 2013 | 09:14 PM
MattyXXL's Avatar
Originally Posted by dougherty93
how exactly would be the best way to do it ?!
No offense, but if you want to do it right buy a civic... You dont do things like that to a volvo..
Old May 14, 2013 | 09:23 PM
ES6T's Avatar
So you want to take air from the roof, behind the engine, and route it through the car, forward, into the engine bay and into the engine? What would the point be?
Old May 14, 2013 | 09:31 PM
ibified's Avatar
If you want to do it right, you don't use a scoop anyway. I've been pondering isolating my air intake in a box and putting a naca duct in the hood just above it.
Old May 14, 2013 | 10:48 PM
Maybe you can add a heater at the same time and share the piping through the roof ???
Or buy a MOPAR kit for a Jeep and modify it for the left side
Old May 15, 2013 | 11:04 PM
Well the idea behind it would be to use the pressure from the scoop to push through the airbox and into the engine.
Old May 15, 2013 | 11:25 PM
migbro's Avatar
To do what? I know what you think it will do and you are wrong.
Why don't you install a throttle body spacer instead. Just as useless but much easier to do.
TacklaNHL
Aug 5, 2010 10:27 AM
xxblindxx
Dec 13, 2009 11:10 PM
98_S70_T5_Driver
Jul 1, 2009 06:35 PM
derekkoop
Apr 29, 2009 10:30 AM
pos960
Jan 20, 2007 04:03 AM
